1983 Mini City
- NeilRichmond
- Whats your location?: Mayo
Re: 1983 Mini City
You should have been supplied with the inserts for the Poly front pear mounts.
Depends on supplier
I have the bolts / washers / nuts and additionally poly mounts - not all -and rubber too
http://www.richmondclassicscarparts.co.uk/
Depends on supplier
Re: 1983 Mini City
NeilRichmond wrote: ↑Mon Mar 01, 2021 8:23 pmYou should have been supplied with the inserts for the Poly front pear mounts.
Depends on supplier
Good to see an Irish based supplier .Your link above should be .ie not .co.uk.
Will items be posted from Ireland or UK and attract duty?
- What Minis have you?: 1974 Aussie Leyland Mini 998 (Clubman front)
Current project is a 1983 Mini 1000 - Contact:
Re: 1983 Mini City
This is the mounting kit I got from minispares - http://www.minispares.com/product/Class ... tings.aspx
That site seems pretty good on prices, be interesting to know the same as what Woody has asked.
Re: 1983 Mini City
An hour or so at the mini this afternoon. Chopped the remaining part of the closing panel on the RH inner wing off, also the top part of the inner wing that's above that closing panel.
I'll make a cardboard template from the LH inner wing and try to patch it that way.
There was also a small amount of rust just on the top of the inner wing, just below the edge of the scuttle panel, patched in a small piece of fresh metal.
Seemed to weld in fine, but had a few pin holes that I ended up chasing.
Went to attach the teardrops to the new front panel, using the bolts from the old panel, bolts felt tight so cleaned up the threads with 5/16 die, offered them up again and the captive nuts broke off the panel! They look to be 5/16 unc rather than unf that was in old panel! Tried the opposite side and it was the same, so new nuts and bolts needed for that...
- NeilRichmond
Re: 1983 Mini City
They indeed use a 5/16 UNF nut and bolt. The part number for the bolt is GFK5184 for your year of Mini.
Re: 1983 Mini City
Made up a small patch panel to close off inner wing. Still having issues with my welding, blowing through very easily whatever I'm doing wrong...
- What Minis have you?: I owned a 1977 Mini 850 when I was in my late teens. I owned a 1986 Mini Chelsea that I imported from the UK. Also owned a MG Metro that was bored out to 1293. Restoring a 1981 Dublin Mini City.
Re: 1983 Mini City
My problem is that I am putting too much heat into the panel when grinding down the welds and warping my patch panels.
Won’t be touching any new panels until I get my technique right and I can do this butt welding with confidence. Damn it’s a different set of challenges compared with thicker steel.
- daniel garry
Re: 1983 Mini City
clamp a bit of flattened copper pipe behind the joint, it'll act as a backing for the weld and will take some of the heat away
are you grinding with a grinding disc or a flap disc? the grinding disc is quicker but not quite as forgiving! i prefer a little slower but not thinning the metal or putting too much heat in
Re: 1983 Mini City
Old sealed beams cable tied in, old bumper sprayed silver and the old grille pop riveted back together, the beginnings of a flower planter...
Gonna stick in a wooden frame to give it some strength, then maybe 2 old wheels and tyres just to finish it off...
Cleans out some of the old parts from the shed. Looks like weather is picking up so might be able to get something done on the car.
Cleaning my welds using a grinding disc, then finishing it off with flap wheel, but maybe I'm trying to take off too much material in one go, I'll try and reduce the amount of material I'm grinding back, hopefully reduce heat build up
Re: 1983 Mini City
I cut the A-post/scuttle panel too high compared to the replacement scuttle - magnum panel so it doesn't go as high on a-post as genuine panel.
Offered the old one back up and scribed what I needed to keep, was about 30mm on RH side, 10mm on LH side. Took my time tacking it back in, then turned the grinder speed right down to reduce the amount of heat transferring into the welds,worked out much better with only a few pinholes to sort.
I am going to cut out and redo the patch on the inner RH wing as the material I used was slightly lighter than the actual wing, so maybe that's why it was blowing through so easily. I have a good section of the old LH inner wing to cut from.
Got my planter finished, ready for flowers
Re: 1983 Mini City
Got a centre cap for the steering wheel, matches the emblem on the replacement grille I got...
I think originally it would of had the 2 spoke steering wheel, but this steering wheel is in pretty much perfect condition and the centre cap is much better than that heavy disc of polished stainless that was wedged in there!
