Missing bolt and what is this?
Welcome to the Techinical of the IMOC.
The Irish Mini Owners Club and its officers provide this service as a service to its members and Mini enthusiasts in good faith and do not endorse or confirm any detail or claim pertaining to items posted by individuals using this forum.
jaydeluxe
Post by jaydeluxe »
I was changing the top engine steady rubber bush when I noticed this yoke was missing a nut & bolt (the one on the farside that is out of view)
1. What is it?
2. How bad is it to not to have a second bolt on that?
3. I think it needs a bolt to be threaded down into the block and then a nut to tighten it on? Is that right?
Thanks!
'01 MPi Cooper
Re: Missing bolt and what is this?
It's a breather for the engine,someone probably removed it to do the steady bushes before and didn't bother putting it back on as it's awkward to put back on
jaydeluxe
Post by jaydeluxe »
I take it that I can't just screw a bolt into it?
'01 MPi Cooper
What is actually missing ( I think) is a stud with a nut and washer. Because its going into alloy the thread on the bottom of the stud will be different from the one you see on top. It will be a UNC thread. You can replace the stud with a UNC bolt.
Dilogoat's Gruff
Post by Dilogoat's Gruff »
Have you got some oil spattering on that side of the engine? It's not the most important part on the engine but I would put one on if you have one.
