Polybush or not?
davem
Whats your location?: Dublin 22
Polybush or not?
Post by davem »
Just wondering about peoples experience or opinions on polybushes or standard?
If polybush, go for a full car set or standard some places and polybush other?
edit: sorry should have mentioned car is a '94 sprite. I will be fitting hi-lo's, cones and KYB gas shocks and haven't decided yet but probably 12" wheels.
CB_Phil
Whats your location?: Dublin,
Modifications: Few bits
Re: Polybush or not?
Post by CB_Phil »
no expert, but from what I know Poly is the way to go & if your doing hte work you may aswell do the lot I reckon
Have tried both. For normal everyday road use, I prefer rubber.
There are two levels of hardness with polybushes and for some bushes there are two levels of rubber. For a road car the biggest differance you'll notice is road noise, if your running a big exhaust you may not notice this.
Personally I run harder rubber on the suspension and poly on the engine steady.
Dylan8660
Post by Dylan8660 »
Which ever way you go just avoid the poly front subframe rear mounts, they are junk, poly may give extra stiffness over rubber in some applications but these are poorly designed offering little strength past the first fit.
