Indicators
Posted: Sun Dec 08, 2013 12:25 am
by antodeco
Hi all,
My indicators have stopped flashing. They flash the first time then stay on/flicker lightly. My hazards still work fine though. any suggestions on how to fix it?
Re: Indicators
Posted: Sun Dec 08, 2013 10:29 am
by macker
replace the flasher unit for the indicators :wink:
Re: Indicators
Posted: Sun Dec 08, 2013 11:10 am
by antodeco
I was originally thinking that but would the hazards not be affected too??
Re: Indicators
Posted: Sun Dec 08, 2013 1:13 pm
by denisg1973
did u try the earths on passenger side behind expansion bottle , I had this problem and I cleaned up earths now fine
Re: Indicators
Posted: Sun Dec 08, 2013 1:57 pm
by macker
antodeco wrote:I was originally thinking that but would the hazards not be affected too??
Nope, flashers and hazards work on seperate units,
one should be located under the dash and the other should be located under the bonnet, but, this being a mini, they could be anywhere :D
Re: Indicators
Posted: Sun Dec 08, 2013 8:31 pm
Assuming this is the '89 Mayfair ( always good to state model on original post) then it has two flasher units unlike later models and no earths behind expansion bottle like later models.
Assuming that the problem is common to both sides and all six indicators are working then most likely it is the INDICATOR flasher unit located behind the speedo.
The other possablity is low voltage caused by faulty altenator or bad connections (including earths). Low voltage would also showup as dim headlights.
Re: Indicators
Posted: Sun Dec 08, 2013 10:26 pm
by antodeco
Sorry, its actually on the 1275GT! I connected the car upto another cars battery in case there was a dodgy voltage. Still the same. I checked fuses and random cables. All seem ok. Any ideas where on the GT it is? Thanks for all the replies.
Re: Indicators
Posted: Tue Dec 10, 2013 5:35 pm
I think its behind the rev counter. If not the 2 flashers are beside each other near the wiper motor.
