headlight not lighting
- Whats your location?: miltown malbay co. clare
hi 99 mini when I turn on lights driver side head and dim not working , also indicator lights faint , checked earths fuses and wiring loom to light also under wing , but no joy , then it decided to work and stop again , any ideas , passenger side is fine high and low beam
Re: headlight not lighting
bullet connectors?, freyed cable?
don't know really, their's not too much to check once their is power going to the lights from the board
sounds like an earth problem, Earth is located behind the expansion bottle, there are 6 spades into one lug. Its worth dismantaling the earth lug and cleaning it out.
sound thanks was that I found it yesterday , all seem to work again now, any good replacement brake light switchs around sick of buyin lucas ones they keep falling apart as cold air feed hits them sometines
I think the ones I use are intermotor from the local motor factor.
