Cooling system capacity
RichyB
Whats your location?: Dun Laoghaire
Post by RichyB »
Hi there, just refilled my cooling system and it seems to be only taking around 2 litres. It's a 1990 998 so the capacity should be 3.5 litres according to Haynes. Thought it was airlocked so I drained it and refilled it very slowly but it still only took 2 litres. Could there be enough residual coolant left in the system ie heater, block, etc to make up to 3.5 liters?
Any help greatly appreciated
Richy
Re: Cooling system capacity
The other one and a half litres is whats left in the block and heater
RichyB
Post by RichyB »
Thought so, didn't want to risk overheating! Thanks a mill Bert!
Flushing the whole system is a worthwhile procedure every now and again.
roryp
Whats your location?: New Ross
What Minis have you?: 1966 Mk1 Morris Cooper
1974 Swiftune Mini
Autotest Mini Saloon
1980 Mini Convertible
Post by roryp »
While you are at it you should put Evans Coolant into your mini. Its fantastic in a mini
