No Engine ecu , help!!!
mini1994
Whats your location?: Cornafean , Co.Cavan
What Minis have you?: 1994 Mayfair 1275 carb
Post by mini1994 »
Hi ,
Im doing a project and due to moving a house i've lost my Ecu . I have looked up old pictures and it said AG on it
Its a 1994 mayfair carb model
Thanks ,
Patrick
Re: No Engine ecu , help!!!
If its a carb model it doesn't have an ecu.post a pic of the part
mini1994
Post by mini1994 »
mini1994
Post by mini1994 »
Thanks for your reply , one like this one but with AG on it
Then it's not a carb mini it's spi :)
mini1994
Post by mini1994 »
Thats a good one :D but there is a carb in it so does than mean i dont need the ecu at all , will it start without it ?
jocelynn
Post by jocelynn »
Can you post a picture of the engine bay?
mini1994
Post by mini1994 »
mini1994
Post by mini1994 »
Does the engine number match the V5?
mini1994
Post by mini1994 »
Sorry what is the v5 ?
V5 = Log book.
mini1994
Post by mini1994 »
i checked and the engine number doesnt match the logbook
Obviously been a swap at some point, does it at least start with a 12 ?
mini1994
Post by mini1994 »
When i bought the car it was starting and driving perfect then i put it fully apart and now im putting it back together , i dont have the loom and fuel tank in so i cant check would it start without the ecu
With a carb you dont need an ECU, instead you have a dizzy and a coil. You also dont need a fuel tank either, just anything to hold a bit of petrol.
mini1994
Post by mini1994 »
That is perfect thank you very much for your help , i will be starting it soon just have to get the loom on , thanks again
cotzy.j
Whats your location?: Northwest Dublin
What Minis have you?: 1990 Mini City 998cc
1994 Cooper 1275cc
Modifications: none
Post by cotzy.j »
This is interesting.
I myself have just bought an automatic '94 Cooper. I bought it before realising it had the ECU removed and a carb installed. Turns out the previous owner spent over €1000 getting the conversion done, along with a modified centre exit exhaust.
but how do people feel about the conversion in general?
And what tuning possibilities should I take advantage of?
Is your Mini still an automatic ?
