Wiring spots
cotzy.j
Whats your location?: Northwest Dublin
What Minis have you?: 1990 Mini City 998cc
1994 Cooper 1275cc
Modifications: none
Wiring spots
Post by cotzy.j »
Bought a set of 2nd hand Wipac Spots (H3 bulbs).
What is the best way to wire them?
Re: Wiring spots
You'll need a relay, inline fuse and opitional switch. You can have the spots always come on with the main beam or have a switch which will control if they come on or not but they must only come on with the main beam for the NCT.
Connect one side of your fuse to the Brown wires at the fuseboard and the other side to the relay ( 30) .
Connect relay output (87) to your spots
Connect relay coil (85) to earth
Connect relay coil (86) to Blue/White feed to main beams either directlly or via switch.
