Hazzard switch
Hazzard switch
ok My 76 clubby has no hazzards ok but I have a hazzard switch and about 10 wires can anybody help me out woth this
Re: Hazzard switch
Any body ???
Re: Hazzard switch
Thought Woody would have replied to this, he's the recognised resident aficionado in regards to things of this nature.
Re: Hazzard switch
there's also a flasher unit required for the hazards, as well as some extra wiring: its possible the wiring may be in place, but as TMG says woody's the man.
Re: Hazzard switch
WOODY any ideas?
Re: Hazzard switch
Sorry lads ,didn't realise I was on 24hour call
Hazard switches seldom give trouble but the flasher and its connector do .Should be just left of the wiper motor. The other common problem is the inline fuse behind the carb.
First thing to do is unplug the flasher and check that you hahe 12 volts at one of the connections.
Re: Hazzard switch
No woody I have none thats wat I trying to do is wire a unit into my mini
- zakgt
- Whats your location?: Maynooth
- What Minis have you?: 1962 - Morris Traveller MK1 - 1978 - 1275GT, 1998 - Sportspack
Re: Hazzard switch
Lads,
I findi Woodys' partcipation on the fourm and this tread in particular to be on/off, on/off, on/off
Re: Hazzard switch
Do you just want to add hazards or do you plan on upgrading other electrics ( fog light ,reverse light ,stalk switches) in which case it would be easier to change loom. If you just want to add hazards I may have something for you to make it easier.
Re: Hazzard switch
No just add hazzards!
Re: Hazzard switch
I also have the hazzard switch unit with about 10 wires coming from it ?
Re: Hazzard switch
I take it yours is an early '76 with the two center switches for lights and wipers and the hazwrd switch you have is a late '76. The best place to tap into the main loom will be at the connector for the indicator stalk and beside the steering colum.
1. you have two double wires on your switch Green/Red and Green/White, you can remove one of each.Join each of these to the same colour cable at the connector
2. You have 2 Light green/Brown from the switch. Cut the Light green/Brown in the loom and join each end to each cable to the switch.
3. At the fuseboard you need to join another inline fuse to the brown cables.
4. This fuse now feeds a hazard flasher unit and the output of the flasher joins the switch on the Light green/Pink cable
5. You then earth the black wire to the switch.
Make sure to use the correct flasher unit 4x21watt + 2X5watt
- purplehaze
Re: Hazzard switch
Eh lost as u can see no pink wires
Re: Hazzard switch
Not pink cable, the system used to describe cables ie Light green/Pink is the main cable colour first (Light green) followed by "/" the colour of the thin strip( Pink).
Hard to judge by the photo but it looks Light green/Pink to me.
List out all the cable colours on your switch
Most of what I said still applies as far as I can see.
