NCT pre check/ work
camroc
Whats your location?: stephens green
NCT pre check/ work
Post by camroc »
hey there, just wondering if there is anyone out there who would get my mini ready for the nct? at the moment all I think needs doing is the tracking, but its a mini so undoubtedly there will be more than just that. Went to a few mechanics and they all said to go to a mini specialist. The car is in rathgar and the closer to there the better :D
Re: NCT pre check/ work
Why don't you put it through first and see what fails, then you won't spend a fortune on things that don't need doing yet.
camroc
Post by camroc »
I thought about it, but the tracking needs to be done anyway, so I figured just have anything else done while im at it
Just do as JP said, as it doesn't matter what you fix on it, the NCT will find fault with something
jocelynn
Post by jocelynn »
Give Paul Kelly a call in minifix in santry. His number is 087 2597085
macker wrote:Just do as JP said, as it doesn't matter what you fix on it, the NCT will find fault with something
did someone mention "quotas"?? Nahh. :mrgreen:
