Last week I found the heater fan out of a Citroen xsara and sized it up to an old heater box so I started cuting and It fited perfectly it blows a lot more air than the standard fan I haven't fingered out how to get the speed working so if any 1 has any idays of how to get different speeds let me no
Citroen fan on the left mini fan on the right
And this is it all put together
heater fan upgrade
Re: heater fan upgrade
The speed control is normally done through a bank of resisters selected from a 4 position switch .Often the resistors are located in the heater were the air flow is used to cool them.
If I could get 1 slower speed and then the full speed id b happy
- joeyfinneran
Does that one squeel as well
Must give it to ya cleaver idea
It's a bit louder than the mini 1 but when I get the speed working that will fix that I can't here it with my exhaust just when I stop its a bit loud
Users browsing this forum: Ahrefs [Bot] and 1 guest
