Fibreglass Flip Front
mini mad sam
Whats your location?: midleton, county cork.
What Minis have you?: 1985 MINI
1991 MINI
1975 MINI CLUBMAN ESTATE
Post by mini mad sam »
Anyone using these anymore??
Re: Fibreglass Flip Front
I've one ill be using on my pickup,
I use one on a classic, wouldn't like to try and NCT one. :(
yes but yours is meant for the snow Woody :lol:
drifthooligon
Whats your location?: edenderry, Offaly
What Minis have you?: 89 austin mini mayfair
Modifications: 1.3 mpi cooper engine, S Works pack
Post by drifthooligon »
just wundering now, instead of starting a new topic i said id revive an old one, does anybody know if a flip front will pass an NCT ? if i go with a flip front im going to be using the bracing from minispares, but will that be enough for the NCT, ive seen threads on the mini forum and some have said that it passed the MOT so are the two not basically the same ?
If duct tape cant fix it theres no hope
It might be best to check with them first.
Have a look at pages 57 to 59 of the NCT manual.
"Fibreglass or similar composite in secondary structure is acceptable."
http://www.ncts.ie/pdf/NCT%20Manual%20R ... 202012.pdf
drifthooligon
well thats a load off anyways, flip front it is so ....
I would still say check with the NCT first
drifthooligon
Will do, even if a complete flip front isnt allowed i could always use a fibreglass front and have the front itself on duez clips and a fibre glass bonnet either on hingeds or bonnet pins
