Looking for advise
- Whats your location?: Annaghdown, Galway
- What Minis have you?: 81 Red Austin Mini Auto HL
Looking for advise
So took the Mini for a spin today, ran fine. Drove about twelve miles and stopped off, on the way home it started to die, didn't conk was going about 15 miles an hour max sounded like it was choking. Red light was fading in and out on the dash. Was having the same problem about four weeks ago and had a new alternator fitted. That doesn't seem to be doing the job. Doesn't seem to be the battery as its starts alright, the problem is in drive. Its an automatic, and if i change it from drive to first seems to bring the life back into it. Anyone have a similar thing?? When it was in the garage he said he couldn't see anything. thanks
Re: Looking for advise
may be that the alternator isn't charging the battery or at least not enough,
check the belt and connections on the alternator, the earth strap for a good connection and the battery leads to make sure they're not worn anywhere, also check the battery isn't on the way out
Sounds familiar, check that the battery cable isn't shorting or melting on the exhaust.
thanks guy looking into all da stuff ye said, thanks for advice
- Whats your location?: Dublin 14
- What Minis have you?: '84 Austin Mini 998, aftermarket softtop conversion (probably done in the 90's), BRG (a shade darker than original), rare headlamp rims with peaks (one piece), 3 piece wooden dash with 2x gloveboxes
- Modifications: 12x fusebox, moved to interior, Hi-Los and Stage 1 kit, W&P Style arches, 12" minilites, 4x Wipac, T7 heater with special Y pieces, 7Ah motorbike battery in engine bay, Powerspark Distributor, reclining bucket seats bolted directly to floor, custom switchboard with MP4 player as headunit and small 20W amplifier, some burr pieces
Hope you got it sorted by now
What was it in the end?
Lucas - Lord of the Darkness
