Wheel bearings
Posted: Sat Oct 20, 2012 3:12 pm
by joeyfinneran
Bought brand new wheel bearings last month
Fitted them to the hubs while looking at the miniaddicts video on youtube and now one month later i hear the grinding through the steering column and theres play in the wheels :?
Realy have to get a different everyday car as this thing is doing my head with a different problem evey week
Re: Wheel bearings
Posted: Sat Oct 20, 2012 3:20 pm
Most likly you didn't tighten the hub nut enough. 200lbs
Re: Wheel bearings
Posted: Sun Oct 21, 2012 10:53 am
Did you use good quality tapered roller bearings ?
Re: Wheel bearings
Posted: Sun Oct 21, 2012 12:11 pm
by joeyfinneran
Cant rember what ones i got
Re: Wheel bearings
Posted: Sun Oct 21, 2012 11:22 pm
by joeyfinneran
today i went at it and they did seem very easy to loosen so i got a 3 meter 2" gun barrel pipe and turned it until the car started lifting of the axel stands :lol:
was using unistrut interlocking on the wheels studs and bent it every way lol ending up using a large adjustable spanner and didn't bend that :)
and after a few miles i hear no sounds and theres no movement in the wheels so i think result :)
Re: Wheel bearings
Posted: Mon Oct 22, 2012 12:59 pm
by DaveC
Did you use a torque wrench?
Re: Wheel bearings
Posted: Mon Oct 22, 2012 1:16 pm
by joeyfinneran
No but the last time i did and i ended up with the slip pin hole not in one of the slots of te castle nut so i just tightened it to the next slot on the nut
Re: Wheel bearings
Posted: Mon Oct 22, 2012 1:26 pm
You need to use a torque wrench on this job to do it correctly and give yourself peace of mind.
Re: Wheel bearings
Posted: Mon Oct 22, 2012 4:51 pm
My torque wrench doesn't go to 200lbs :(
I find 3 grunts just about right.
Re: Wheel bearings
Posted: Mon Oct 22, 2012 9:48 pm
Aldi have torque wrenches this week, don't know what rating though.
