mainshaft needle roller bearing
briain
Post by briain »
I'm trying to take the needle roller bearing off the mainshaft of the gearbox and it doesn't seem to want to come as the cage is plastic I am a bit hesitant to use a puller on it any ideas?
Re: mainshaft needle roller bearing
Normally it just slides out. If its damaged or your just replacing it it doesn,t matter how it comes out. If its not damaged just leave it in.
briain
Post by briain »
This is the smaller bearing at the end of the shaft I can't undo the smaller nut till its off I don't mind breaking it its not expensive to replace but don't want to damage anything
You can pry out rollers one by one and remove the cage then use a puller on the metal part to remove it.
I think you mean the first motion shaft bearing, I was thinking the one between first motion and main shaft.If I remember right I used two flat screwdrivers as its too narrow for a bearing puller.
briain
Post by briain »
Cool, will try that just didn't want to force anything and damage parts
memory comming back slowly ( getting old ) ,two claw hammers . One each side and pull evenly, careful not to chip a tooth on the gear.
