SRS Light and NCT
Posted: Mon Sep 03, 2012 8:11 pm
by JohnFM12
Hi all, I'm in for NCT tomorrow and the SRS light is on in my car (1998 MPI Cooper) My local garage hasnt got the software to turn it off, Is there any way of doing it myself, or is there anywhere in Meath/Dublin that could do it for me?
Thanks in Advance
Cheers
JOhn
Re: SRS Light and NCT
Posted: Mon Sep 03, 2012 10:38 pm
Remove the bulb ?
Posted: Mon Sep 03, 2012 10:54 pm
by JohnFM12
I was thinking that, will it pass the nct? I've all the pugs disconnected along with the battery and I just cant get the plug out of the airbag ecu. I have them all sprayed with contact cleaner as the car was lying up for years.
Any ideas how to remove the plug?
Cheers
John
Posted: Mon Sep 03, 2012 11:04 pm
by jocelynn
Try Paul kelly in minifix in dublin 087 2597085
Posted: Mon Sep 03, 2012 11:18 pm
by JohnFM12
Will do, thanks a million
Cheers
John
Posted: Tue Sep 04, 2012 10:10 am
by BERT
If you remove the bulb it will fail,the system tests its self and if everything is ok the light will go out,if theres a problem it will stay on
Posted: Tue Sep 04, 2012 10:28 am
by Mark B
I'm having the same problem, NCT on thursday. The light was staying on yesterday but its back to normal today.
Mark
Posted: Tue Sep 04, 2012 1:06 pm
You can only reset/turn light off if the fault is cleared. Reading the ecu should tell you what the fault is so you can fix it.
Posted: Tue Sep 04, 2012 8:56 pm
by JohnFM12
Thanks lads, went over to the chaps in Minifix and they steered me in the right direction
Sound men and only 15mins up the road! Got some advice and tips off them too,
Happy days
Cheers
John
