engine serial numbers
jjfarrelly92
Whats your location?: Whitegate,
Virginia,
Cavan
What Minis have you?: 1988 Mini 1000
1980 Mini 1000
Post by jjfarrelly92 »
where do you find the serial numbers on an engine block? I know thats a really rookie question.
thanks
Colum
DAVEY_C
Re: engine serial numbers
Post by DAVEY_C »
when your looking at the block from the front as it would sit in a mini the stamp should be infront of piston no1 (1st piston from rad) but if the block has been skimmed at all the numbers will not be present...
jjfarrelly92
Virginia,
Cavan
1980 Mini 1000
DAVEY_C wrote:when your looking at the block from the front as it would sit in a mini the stamp should be infront of piston no1 (1st piston from rad) but if the block has been skimmed at all the numbers will not be present...
Thanks so much!
