Loosing water
vincieshile
Whats your location?: Donegal
What Minis have you?: Austin Mini City 998
Loosing water
Post by vincieshile »
Every time (every 2 weeks or so = 100 miles) I check the water level in the radiator it takes about 2 pints. Is this common? I don't know where the water's going.
Re: Loosing water
Put cardboard under d car Wen u park it up for the nite.... check it nxt day... try keep it out of d rain. As. U no y. Haha... leaky rad or pipes. Check thermostat housing. Dats all I can tink of mate hope it helps
_mini1000_
Re: Loosing water
Post by _mini1000_ »
also worthwhile checking the heater matrix as it could be leaking through that
Re: Loosing water
Deffo not normal.If its not leaking out it could mean its leaking into the engine. Possable head gasket failure, any overheating or smoke/steam from the exhaust?
Re: Loosing water
check the oil for water... . its either leaking out or leaking in....
Re: Loosing water
And remember out is good in is bad :lol:
Re: Loosing water
the bearing might be on its way out on the water pump,
If it is, water will weep out through the little hole under the pump and get blown out through the rad or evaporate off it
vincieshile
Re: Loosing water
It's the bloody head gasket :cry: What do I do now. Thursday is my only free day before MTM. Help!!!
Do I go mad or do I do something constructive???? :x
Re: Loosing water
If your happy you didn't overheat the engine then just get the gasket changed. If you did overheat it (boiling steam) the head will need a skim. Should only take a couple of hours.
Re: Loosing water
just to be safe get the head skimmed anyway, 1 hour job and then its fairly easy on a mini, get a gasket kit from ur motor factors, bout 30 to 40 quid, and do everything mate, get a good gasket sealer too. bout 5 euro, that kit includes a copper head gasket, and should take bout 2 hours to complete, i did one myself and i dont even own a rachet set hahaha :) hope all goes well mate
Re: Loosing water
You don't need sealer on a head gasket, but you do need a good torque wrench to do up the head nuts properly, also make sure you do them in the correct order.
You may also need an exhaust gasket which might not come in a head gasket kit.
vincieshile
Re: Loosing water
Got Mervyn Johnston to sort it for me yesterday morning. Now packing for Malin. Where's that list again - tyre weld, spanners, jar of petrol, jar of water, jar of red bull, etc. etc......
Re: Loosing water
vincieshile wrote:Got Mervyn Johnston to sort it for me yesterday morning. Now packing for Malin. Where's that list again - tyre weld, spanners, jar of petrol, jar of water, jar of red bull, etc. etc......
You can't beat the Tullyhommon Flyer 8)
