Help Needed!!
- Whats your location?: midleton, county cork.
- What Minis have you?: 1985 MINI
1991 MINI
1975 MINI CLUBMAN ESTATE - Contact:
Help Needed!!
Hi when I'm driving my mini if i brake, slow down or change gear there is a loud bang and a judder from the left side wheel (i think).
I checked engine mountings, they are good.
Any idea what could be wrong??
Thanks.
Thanks.
- purplehaze
Re: Help Needed!!
Could be any thing. I had same prob from mine. My ball joints were Nackered...could be wheel bearings or drop links. Jack the car up an wiggle the wheel hand on top of wheel and other hand on bottom. Pull an push on it. If it wobbles its either wheel bearing drop links or ball joints. Hope this helps
Re: Help Needed!!
Drop links???
- purplehaze
Re: Help Needed!!
Minis don't Hav drop links... haha. Honda on d mind haha
Re: Help Needed!!
wheel bearing, balljoints, trackrod end , tiebar rubbers. Take the wheel off and look.
Re: Help Needed!!
the bang could be caused by worn engine steadies and the exhaust,
if the steadies are worn when you slow down the engine rocks and lifts the back of the exhaust manifold hitting it off the underside of the car which might be your bang
1991 MINI
Re: Help Needed!!
found wat was wrong!!
lower tie rod broke where it attaches to the subframe.
Re: Help Needed!!
Is the subframe damaged, Sam? I have tie rods and a subframe if you're stuck.
1991 MINI
Re: Help Needed!!
hi billy,
it broke where it bolts on to the subframe, just wondering could i weld a new bracket on to the subframe to take the tie rod end?
Re: Help Needed!!
short answer, yes
It is the "L" bracket one that's on the front of the subframe on the drivers side isn't it?
Re: Help Needed!!
Can you post a picture? Have never seen the subframe break there before, what condition are the rubbers in?
