Problem that I would like help with
Hi I'm looking for somebody that can have a look at my mini and fix my problem . I have a very small bit of water under my foot peddles . Need to know if water is coming in from bad door rubbers or under floor. Floor looks good but need someone that knows their way around a mini and has a lift to inspect . Thanks Philip
- Whats your location?: Glenageary, Co. Dublin.Ireland
- What Minis have you?: 2000 Cooper Sport
Re: Problem that I would like help with
What part of the country are you.
I'm in Palmerstown in Dublin cheers
Give Paul Kelly a ring in minifix he based just beside Dublin airport his number is 0872597085
i had a similiar problem, took it to a mate and he said it was the front window seal, the water was coming in and dripping down to the floor under the pedals, he stuck a bita sealer in the window seals and it seemed to work
- Whats your location?: kerry
- What Minis have you?: 1986 mini mayfair
Could be something to do with a leak on the heater unit,
- What Minis have you?: Mini city
Is it definately water. If your clutch master cylinder is leaking it will drop a bit of fluid down behind the pedals and that will roll down onto the floor.
