4 pin diff assembly
ian o B
co. longford
4 pin diff assembly
Post by ian o B »
Hi all, hoping someone might be able to shed sum light here..
Recently purchased a minispares 4 pin diff, i assembled it following the instructions given..
all was turning fine with the first output shaft and 4 planet gears in the cage.. with the second output shaft in it started to turn less easy :| sticking slightly..
then with the crown wheel and 6 bolts on the hole diff became locked (even finger tight). neither output shaft could be turned by hand.. this is hardly right ???? :?:
i assumed this was wrong so i took it apart and tried again..same result. then tried it with the old fibre washers then without.
no luck.. but noticed the diff turns before the 6 bolts are tightened
more than likely im missing something simple :lol:
any help apreciated thanks
DAVEY_C
Re: 4 pin diff assembly
Post by DAVEY_C »
would this help with the assembly??
http://www.guess-works.com/Tech/Xpin.htm
ian o B
co. longford
Post by ian o B »
Thats a great link davey :)
but unfortunitly dosent help with the problem of the diff being locked when fully assembled, :?
minionly
Post by minionly »
Ian u broke it
How much end float is there in the diff with no fibre washers in place ?
ian o B
co. longford
Post by ian o B »
Got this sorted with a few hours of sanding fibre washers assembling..and taking the diff apart.. countless amount of times!
now turns freely as it should. :o
