Newbie Question
Stuie.91
Whats your location?: Lucan Co.Dublin
What Minis have you?: 1996 Mini Cooper 35 Anniversary Edition
1968 Riley Elf Mk 3
1974 Mini Pickup
1986 Ratlook City
1978 Irish CKD Mini Van
Modifications: Majority of the cars are stock with few custom stuff on engines and exhausts, suspension, wheels
Newbie Question
Post by Stuie.91 »
Hi my name is Stuart I am new to this whole mini thing. Always wanted one so finally bought one last week. I will have to NCT it the next few weeks and was wondering if there is any major things to have looked at before I even book an NCT. Don't want to book it in if it is an obvious fail. I have a 1996 Cooper anniversary edition it has had loads of work done on the engine by the previous owner and from what I can tell drives great.
Any help appreciated. Thanks
Re: Newbie Question
Welcome Stuart: there as many schools of thought regarding NCT prep as there club members i think... handbrake adjustment is probably the easiest/most likely issue, all other things being ok. check the bulb in the rear foglight too.
i wonder was there much work done to the engine *since* the last NCT? later minis like yours have a fairly strict emission test and can be tricky to pass if extensivley modded.
where abouts are you based?
Re: Newbie Question
As Keith says about loads of work done on engine!!
Check under the car for any rust ,if you see any clean and prime it.If you see a hole fill it and prime it. What the NCT guys don't see they can't fail you on.
Dylan8660
Re: Newbie Question
Post by Dylan8660 »
Grease your ball joints and rear swing arms.
Re: Newbie Question
best advice I could give you aswell as whats written above would be to make sure your water bottle is full,
windscreen wipers are working properly,
tyres are pumped to the correct pressure,
lights inside and out are all working,
number plates are both legal and on the car,
seat belts are in good working order, and the emissions are good,
and then pull together as much money as you can to fix whatever it's gonna fail on because it could fail first time,
but at least if it does fail on anything after this you will now know what needs fixing to get it through on the retest :D
Re: Newbie Question
If you wanted to bring it down as far as greystones il look over the car for you
Re: Newbie Question
macker wrote:.......number plates are both legal and on the car............
......... and the emissions are good..........
Good advice Macker......... Ah huh........
So i'm sure these things are 100% on your motor...... :lol:
tommy1
Whats your location?: wicklow
What Minis have you?: 1275 mayfair auto.
Modifications: stage 1 kit
Re: Newbie Question
Post by tommy1 »
by the way check the tyres have e stamps on them i got caught with 1 tyre that didnt, especially if it hasnt had a change in a while. and welcome to the site enjoy :D :D
Stuie.91
1968 Riley Elf Mk 3
1974 Mini Pickup
1986 Ratlook City
Re: Newbie Question
Post by Stuie.91 »
Thanks for the feedback and help
just one query what are the correct tyre preassures for the car. It has Minilites with 145/70 R12 tyres on it.
Thanks again
clubmankev
Re: Newbie Question
Post by clubmankev »
2 bar all round, with the tyres cold.
MINI
...where size doesn't matter!
Re: Newbie Question
Absoposidefilutely! :D
but sure you know mine is exempt....... ah huh.........thank you very much! :lol:
Re: Newbie Question
clubmankev wrote:2 bar all round, with the tyres cold.
At sea level :wink:
