Painting rubber arches
Evlabe
Whats your location?: Athlone
Post by Evlabe »
Does anyone know which brand of primer is best for painting the rubbery sports pack arches. The ones on my car were painted by the previous owner and are very badly cracked. Wherever you touch the arches and bend them slightly more cracked paint appears. I reckon they used the wrong primer and paint. (maybe the answer is not to bend them!!!) any advice would be welcome. Gareth
minis24se7en
Whats your location?: Mayo.
Re: Painting rubber arches
Post by minis24se7en »
I've painted these rubber type arches before and never had a problem. Painted them off the car and and then fitted them without cracks. (One of the minis even had a front end smash and the paint survived!)
I would probably say whoever painted them didn't prep them properly. They would need to be scotched or water paper sanded to take the shiny plastic finish off them, then the new paint has something to stick to and little or no chance of cracking or chiping.
Aside from that there IS a "plastic primer" you can get, brands don't really matter, they all do the same job. Just use it the same as any other primer..... prep the arche - plastic prime it -prep it - paint it :)
Evlabe
Post by Evlabe »
Nice one thanks for the info, I'll give it a go and see what happens !!
GTM Coupe
Post by GTM Coupe »
You will need to remove all the existing paint as the original paint has not stuck and therefore if you paint over it with correct paint it will just peel off because of the existing stuff.
