Points and condensers
- Whats your location?: Ballivor Co. Meath
- What Minis have you?: 81 city
- Modifications: Its in bits at the minute
Re: Pionte and condensers
Get rid of them then
http://www.ebay.co.uk/itm/Mini-59D-Powe ... 1c15794e94
There is also a britpart kit available for land rovers that fits and does the same thing for less money
Jesus gonna order that on payday
Just make sure you get the right one for your dizzy
Oh theres a diffrence
Re: Pionts and condensers
Quick question i changed the on pionts my mini the other day drove it round the block less less than 1 k seemed ik so to day I was gonna go for a drive started it up let it warm up a little so I started to drive off and its all spluttery I thought I got the gap wrong or something bu on closer inspection the blue plastic bit on the pionts are melted a bit can anyone explain wats go on here
Anybody
A failed or incorrect condenser can give a very big spark at the points, which can pit or burn the points. Not sure what part of your points are burning, but i would check you have the correct condenser and it's correctly installed.
Re: Points and condensers
Two possabilities
1. the cam that the blue plastic runs on should be lightly greeased to stop the plastic wearing.
2. too much current running through points can heat them and melt blue plastic. Faulty condensor, wrong coil ,points too closed.
