help on getting spark
lewis
Whats your location?: Cavan
What Minis have you?: ..1989 Austin mini 998cc 1979 mini clubman 1275 cc
Post by lewis »
Hi, I can get my engine going its a 998cc all wire is right but does not same to be getting spark i think its the distributor has a new cap on it also, does any 1 no wat I can do to make it run
Photography at its best..........Photoshoots done for all car MINI's
molly the mini
Re: help on getting spark
Post by molly the mini »
Is there a spark comeing out of the coil
lewis
Post by lewis »
no and i tryed a new coil and still nufin
points, condenser??
lewis
Post by lewis »
what way do you set dem/ distributor
was the rotor arm replaced with the dissy cap?
sometimes they don't match up properly and you won't get a spark or only get a weak spark?
GTM Coupe
Post by GTM Coupe »
If you don't know what you are doing its very hard to even talk someone through the setup, probably best have a professional look at it.
briain
Post by briain »
check the engine bay earth really easy way of doing this is to use a jump lead between the engine and the body
lewis
Post by lewis »
thanks got her going and the car is almost ready for the road / MTM i hope
