quick question
Posted: Sat Jan 28, 2012 9:22 pm
by jamesb
i have a 94 mini cooper and once you start it it ticks over perfectly then once it starts to get warm it starts to splutter as if it is out of petrol and then cuts out. any ideas what the problem is ??? or is there any one around roscommon that could take a look i cant figure it out thanks
Re: quick question
Posted: Sat Jan 28, 2012 9:53 pm
by keith
first place id look is at the vacuum pipes between the manifold & the ECU.
Re: quick question
Posted: Sat Jan 28, 2012 9:59 pm
by jamesb
keith wrote:first place id look is at the vacuum pipes between the manifold & the ECU.
what do i look for leaks is it? thanks
Re: quick question
Posted: Sat Jan 28, 2012 10:04 pm
by molly the mini
Pm'ed
Re: quick question
Posted: Sat Jan 28, 2012 10:07 pm
by jamesb
molly the mini wrote:Pm'ed
what does Pm'ed mean ???
Re: quick question
Posted: Sat Jan 28, 2012 10:10 pm
by keith
jamesb wrote:keith wrote:first place id look is at the vacuum pipes between the manifold & the ECU.
sorry, yea. the pipes and rubber joins get very warm and crack with age, leaking. take the vacuum pipe off the ecu and you should feel a good vacuum at idle, warm.
Re: quick question
Posted: Sat Jan 28, 2012 10:15 pm
by jamesb
keith wrote:jamesb wrote:keith wrote:first place id look is at the vacuum pipes between the manifold & the ECU.
thanks i'll try that cheers
Re: quick question
Posted: Sat Jan 28, 2012 10:39 pm
by macker
jamesb wrote:molly the mini wrote:Pm'ed
It means you have been privately messaged by a member and this message can be found in your inbox
Re: quick question
Posted: Sat Jan 28, 2012 11:16 pm
by jamesb
macker wrote:jamesb wrote:molly the mini wrote:Pm'ed
sorry new to this site thanks.
Re: quick question
Posted: Sat Jan 28, 2012 11:49 pm
by macker
jamesb wrote:sorry new to this site thanks.
No need to be sorry
Welcome to the forum
Re: quick question
Posted: Sun Jan 29, 2012 9:23 am
by kerryminigringo
Welcome along James,good luck with your Mini.
