quick question
- Whats your location?: roscommon town
- What Minis have you?: 94 mini cooper
- Modifications: fully restored with a zeemax kit
quick question
i have a 94 mini cooper and once you start it it ticks over perfectly then once it starts to get warm it starts to splutter as if it is out of petrol and then cuts out. any ideas what the problem is ??? or is there any one around roscommon that could take a look i cant figure it out thanks
Re: quick question
first place id look is at the vacuum pipes between the manifold & the ECU.
Re: quick question
what do i look for leaks is it? thankskeith wrote:first place id look is at the vacuum pipes between the manifold & the ECU.
Re: quick question
Pm'ed
Re: quick question
sorry, yea. the pipes and rubber joins get very warm and crack with age, leaking. take the vacuum pipe off the ecu and you should feel a good vacuum at idle, warm.jamesb wrote:what do i look for leaks is it? thankskeith wrote:first place id look is at the vacuum pipes between the manifold & the ECU.
Re: quick question
thanks i'll try that cheerskeith wrote:sorry, yea. the pipes and rubber joins get very warm and crack with age, leaking. take the vacuum pipe off the ecu and you should feel a good vacuum at idle, warm.jamesb wrote:what do i look for leaks is it? thankskeith wrote:first place id look is at the vacuum pipes between the manifold & the ECU.
Re: quick question
It means you have been privately messaged by a member and this message can be found in your inboxjamesb wrote:what does Pm'ed mean ???molly the mini wrote:Pm'ed
Re: quick question
sorry new to this site thanks.macker wrote:It means you have been privately messaged by a member and this message can be found in your inboxjamesb wrote:what does Pm'ed mean ???molly the mini wrote:Pm'ed
Re: quick question
jamesb wrote:sorry new to this site thanks.
No need to be sorry
Welcome to the forum
Re: quick question
Welcome along James,good luck with your Mini.
