need new parts!!
Posted: Mon Jan 23, 2012 11:23 pm
by Niamhy
does anyone know where i can pick up a fuel injection system for a 93 mpi? i also need a pair of shocks, a barring for the back right wheel and a CV joint for the front left...any good websites i could go to to have a look for them?have a mini magazine that has a few websites in it but just thought that someone on this might have a better idea
thanks in advance
Re: need new parts!!
Posted: Mon Jan 23, 2012 11:47 pm
by spud1979
Look up Miniquip up the north, the owner Ian is on here, delivers down south and next day delivery most days.
Posted: Tue Jan 24, 2012 12:00 am
by jocelynn
Give Paul Kelly a ring in minifix in dublin
087 2597085
Posted: Tue Jan 24, 2012 7:43 am
by minionly
Id defo try ian in MINIQUIP he is always happy to help
Posted: Tue Jan 24, 2012 9:32 am
by kona
why do you need the whole mpi fuel system? Are you sure you dont have a spi engine?Its expensive to get all the parts together! The other stuff you can get in your local motorfactors. A cv is usually around e50 for a outer, wheel bearings are about e40. Make sure you get a good brand such as timken or skf.
Posted: Tue Jan 24, 2012 10:51 am
by keith
MPi's were launched in 1997. (
http://www.youtube.com/watch?v=iodnXn9oQAg) previous to that its likely that the mini is SPi.
here is how you can tell: the SPi's have a coil: (silver tube bolted to left of engine)
MPi's have a transistor pack: (black box bolted to front of engine)
As kona says, fuel injection is a bunch of parts working together... . chances are if its running badly its one or two parts not working correctly. *much* cheaper & easier to find them and replace as needed.
Additionally, on the SPi, the most common fault for poor running is broken or cracked vacuum pipes from intake manifold to ECU - an easy and *very* cheap fix. less than Euro 10.
*edit*
just had a look at your pics again. This:
is an SPi
Posted: Tue Jan 24, 2012 2:59 pm
The bearing and CV can be got locally or Ian in Miniquip.
From the photos your car is deffo SPi.
Is it Bert saying you need a new injection system ( very unusual) if so maybe you could ask him to make a more specfic post. I have most SPi parts available secondhand if needed.
Posted: Thu Jan 26, 2012 12:32 am
by clubmankev
Radiator at side of engine : SPI.
Radiator at front of engine : MPI.
Posted: Thu Jan 26, 2012 10:33 am
by BERT
Its an spi, the injector in the throttle body is damaged theres a vacum nipple broke off at the back of the manifold ,When it came down there was vacum hoses missing and dissconected ,have it running much better but still hesitates when you put your foot down also the spade connector is gone off the bottom of the throttle body,so in my opinion its easier to get a second hand throttle body/manifold rather than repair whats on the car
Posted: Thu Jan 26, 2012 10:43 am
by keith
BERT wrote:Its an spi, the injector in the throttle body is damaged theres a vacum nipple broke off at the back of the manifold ,When it came down there was vacum hoses missing and dissconected ,have it running much better but still hesitates when you put your foot down also the spade connector is gone off the bottom of the throttle body,so in my opinion its easier to get a second hand throttle body/manifold rather than repair whats on the car
sounds fairly broken right enough Bert. Happy New Year btw, you've been really quiet, thought the internet to Wicklow was broken!
Posted: Thu Jan 26, 2012 1:03 pm
by BERT
Same to you!Bought myself a ramp and havent stopped since i got it!makes life alot easier!
Hope to do the MTM this year when i fix the mini.
Posted: Thu Jan 26, 2012 1:10 pm
by minionly
Thats good to hear and also a good advert
Posted: Fri Jan 27, 2012 2:19 pm
I have 2 throttle bodies ,one still on the manifold if you need.
