HRE on 3 month Sabbatical
- Merlin
Hi all,
I would just like to make a Public announcement to all presence and Future customers that I am Currently Taking a 3 Month Sabbatical From the Garage to pursue another path which has arose, I will be still in the loop and completing projects in hand, but will not be able to take on any more work at present. However the Mobile will still be on and I will help out anyone I can who is stuck.
Sorry for the Inconvenience this may cause anyone but times are hard and I cannot Turn down opportunity.
Thank you to Every one of my customers for the support in the past and to All the forum members here and on other forums for the continual support that you have given me through the past years.
I will Update you all as soon as I am in a capacity to take on work again part time or full time which ever it may be,
Happy New year all,
Regards,
Paul.
Happy New year all,
Regards,
Paul.
Re: HRE on 3 month Sabbatical
Good luck with the new adventure Paul.
Ah balls
- Whats your location?: Mayo.
Times are hard, but it's always exciting starting a new venture.
A new year and a new opportunity, the very best of luck Paul, hope all goes well
Shane.
Shane.
Hope it all works out for you Paul,best of look in the future and hope the new venture is a success.
Best of luck pauly
good luck to you Paul.
Note to self - Dont change gear for 3 months
