changing rear passenger light
Posted: Wed Nov 16, 2011 8:31 am
by tommy1
Re: changing rear passenger light
Posted: Wed Nov 16, 2011 12:27 pm
by macker
just undo the strap that holds the tank in place and wiggle it over out of the way from the bottom, the filler neck should come back in through the hole, you don't need to move it much though,
you should be able to reach the nuts then to undo the lamp
Posted: Wed Nov 16, 2011 12:33 pm
by tommy1
thanks macker ill have a go if this lovely weather goes away, cheers, by the way would it benefit me to silicone around the seal under rubber rather than using the sticky tape, thanks again
Posted: Wed Nov 16, 2011 1:43 pm
by macker
i wouldn't advise using silicone anywhere near a painted surface, especially on minis since they are prone to tin worm,
why were you going to use it or the tape anyway?
Posted: Wed Nov 16, 2011 6:21 pm
by tommy1
i had just got it back from workshop and the guy who sprayed it had taken out lights and had a sort of double sided foam tape inside the light unit itself but it let bthe water in so hence having to change it, i thought it needed to be there so was thinking silicone rather than the tape, its not touching body its the seal from the lens to unit, sorry bout the confusion, thanks again.
Posted: Wed Nov 16, 2011 7:07 pm
you can buy replacement seals.
Posted: Wed Nov 16, 2011 7:18 pm
by tommy1
could i get them in any motorfactors or does it have to be a mini special or just a roll of that tape and cut to suit???
Posted: Thu Nov 17, 2011 10:16 am
Somerford ship on the day if you order before noon, 3 days post to Ireland is about the norm.
http://www.somerfordmini.co.uk/eshop/in ... page&id=79
Or you could try Ian in MiniQuip up north, he is on here a fair bit
http://mini-quip.co.uk/
Posted: Fri Nov 18, 2011 9:01 am
by tommy1
thanks a mill for all the help guys and ill be onto ian for the seal asap, thanks tmg
