83 City Wiring Question
Scoobasteve7
Post by Scoobasteve7 »
Hi. I was just wondering if anyone could tell me the correct wiring diagram that I should be following for an 1983 City?
I've been following the Wiring Diagram 11 in the Mini Haynes Manual but some of the wires dont match up so I said I'd ask if anyone knows??
The car is an unmodified 83 carb, alternator with a centre clock dash.
Thanks for the help. :)
jd's mini
Re: 83 City Wiring Question
Post by jd's mini »
wiring diagram 15 or 16
Scoobasteve7
Diagram 15 is for a Mini Special though. mine's just a standard city.
Diagram 16 is for a 1984 onwards...mine is 83.
Scoobasteve7 wrote:Diagram 15 is for a Mini Special though. mine's just a standard city.
dam all difference in the 83 and 84 i'd say, probably just the clocks
Diagram numbers vary with different editions of the haynes manual. I presume your city has the single centre speedo .
Most likly ; Mini 850 Saloon,Van and Pick-up- 1976 onwards.
