engine timing
- Whats your location?: ballytore,kildare,ireland
- What Minis have you?: 1972 mini automatic
- Modifications: spax back shocks
rc40 back box - Location: kildare
engine timing
hi having trouble with engine timing on my automatic engine we ve kept trying and tryin to find the markin but no sign,Is there
another way of setting the engine timing
Drumbrakes:going fast but aint stopping
Re: engine timing
I've never timed an automatic but I can't find any referance to it being anywhere else then being on the flywheel/torque converter like the manual. With the inspection plate open and sparkplug one removed rotate the engine slowly by hand and when the piston is at the top of the bore you should see the marks.They may need to be cleaned and I usually mark them with tipex which shows up better with the strobe light.
- CLUBMANGT
Re: engine timing
Make sure its at the top of the power stroke, pull the dizzy cap and make sure the rotor is pointing to number one plug HT
or pull the rocker cover and make sure both valves are fully closed ie tappets loose
Re: engine timing
To see the timing mark it won't matter if its the power stroke or not ,once the piston is at the top TDC so will the timming marks.It will matter if you want to set the static timing .
- CLUBMANGT
Re: engine timing
Well yea that is true , to see them, once its at T.D.C. I know very little about autos but its a long time since I have seen a mini with an inspection cover on the flywheel housing. I remember useing a mirror to see the marks doing that way
very many moons ago
Re: engine timing
As far as I remember the timing marks on the pulley wheel only came with the introduction of the A+ engine in 1981.
TMG is the automatic expert ,surprised he hasn't confirmed of corrected me on the location of the marks.
I'm also assuming its the original '72 motor.
Re: engine timing
ye its still the 72 we ve being with a mirror for a couple of days
- Whats your location?: Seaforde, Ballynahinch, Co. Down
- What Minis have you?: 1961 Austin 7, 1988 Mayfair, 1964 Van, 1981 van, 1976 Pick-up, 1980 Pick-up, 1968 Wolseley Hornet, 1978 1275GT, 1986 Rally special
Re: engine timing
Sorry I couldn't enlighten you more last night Tommy, next time I'm down I'll try and remember to bring the timing light and we'll set it up on the button for you, then I'll tweak the carb a little to get it at it's best...
Are you going to change you handle on here once you stick the new engine & box in over winter...? or will you just not use reverse seeing your not used with having it anyway...? lol
Ian
MINI QUIP
http://www.mini-quip.co.uk
MINI QUIP
- Merlin
Re: engine timing
Woody your spot on the timing mark is view trough a hole in the torque converter housing,
Your also right it is not nessarly to setup the motor on TDC Piston no1 as the timing light is triggered by piston no1 lead.
___________________________________________________________
Visit HRE website
http://www.hre.ie
or Visit our Facebook Page
http://www.facebook.com/pages/Hickey-Ra ... 2277766935
Visit HRE website
http://www.hre.ie
- Whats your location?: clondalkin
dublin - Region: Eastern
Re: engine timing
anyone know how to do the timing properly on a mini engine.from what i'm told its a 1.3 engine,i have stripped it for painting done the clutch put it back together but i'm told i have to set the timing
,and i know diddly about engines
thanks in advance
- CLUBMANGT
Re: engine timing
I think we may have all missed the point here . Is the car on a carb and if you dont have a timing light ? if the car has a points dizzy and you can't find any timing marks you can get it close the old school way . Find as close as you can TDC of the power stroke on number one cylinder in the way I discribed then turn the dizzy to point the rotor to no 1 lead . Get a body to spin it over as you turn the dizzy slowly and slightly if the leads are set up right it should start . But it must have marks , did you have the dizzy out ? I have seen them run but ,badly with the dizzy 180 degrees out and you wont see marks with a strobe light .
Re: engine timing
think we have timing ok now just more carb tuning to do
