over heating loss of coolant
- miniroar
- Whats your location?: if I had a garage probably in there!
- What Minis have you?: 1990 BRG and 1972 Saloon
- Modifications: Roll cage,custom dash/smiths gauges, Sony xplod ICE 15" sub boot build, 6 x 9's under rear seat,13cm dash, amp built into parcel shelf, Blue angel eyes,neons, MR2 seats, zeemax kit, superlights 13 x 7
mini was overheating on me on the way to work yesterday, when I pulled over all the water was gone out of radiator, top her up and got her home and where the bottom hose joins the waterpump theres a constant drip is this just simply that I need to to tighten the clamp/add extra clamps? just had the head gasket done last week coolant top up'd saturday.
Re: over heating loss of coolant
Id bring it back to who ever done it to be honest
- miniroar
I'll tighten it up and give her a run tomorrow, also battery keeps running down despite been driven everyday dodgy alternator?
- DaveC
Or bad connection of battery terminals?
Or bad earth?
Or bad earth?
I would check the water pump too. If the bearings are gone in it you will see it leaking from one of the holes in the pump housing. Its usually the top hole and very obvious or it can be the bottom hole which is difficult to see.
Top hole can be seen here:
http://www.flickr.com/photos/stevipedia/4506066679/
- miniroar
think your on to something there tightened the hose but there is a constant dripping under the waterpump but I can't see exactly where it is, 'the beard' might be popping up later for a hand
cheers!
- Kenneth Murphy
[quote="miniroar" 'the beard' might be popping up later for a hand
[/quote]
jaysus dont let him touch it!!!! he'll try put a honda in it
