VIN NUMBER
mini_mick
Whats your location?: kildare
VIN NUMBER
Post by mini_mick »
Hey,
Looking for help just finished putting my new scuttle panel in today :D i am told i need put my vin number on it.
Im nearly 100% sure its put on gutter lip of scuttle but what im stuck on is where do i have to print it on it and is it put on a plate or is printed straight to the panel and is there a certain size this should be.
thanks.
Re: VIN NUMBER
Copy the old panel
mini_mick
Re: VIN NUMBER
Post by mini_mick »
thats the thing i had that idea but i stupidly scraped it thinking i wouldnt need it again .
Re: VIN NUMBER
the vin number isn't stamped into the bodywork, it's rolled into it .
DOUGAL
Re: VIN NUMBER
Post by DOUGAL »
Get a set of punches & punch windscreen panal where lip of bonett closes down.
Ive done this several timis for nct .
Prop the panal with a bit of heavy flat metal ( take off bonett ) .
Do a trial run on a piece of metal to gauge the amount of force needed for hammer .
If youve already primed & painted panal clean it back to metal then punch .
hard to get a good mark through a lair of primer & paint .
DOUGAL
mini_mick
Re: VIN NUMBER
Post by mini_mick »
thats great help dougal thanks have better idea what i have to do now got set punches & punch today so do few trial runs now an see how it gose.
mgb1978
Re: VIN NUMBER
Post by mgb1978 »
It will be very difficult to do this properly without bending the scuttle panel......the scuttle panel you just spent time and money on.
Get a set of punches and punch the number on the driver's side inner sill (or somewhere else where you will do less damage than the scuttle).
The NCT crowd will only want to see the number punched onto the car somewhere, they really don't mind where as long as you can show it to them.
mini_mick
Re: VIN NUMBER
Post by mini_mick »
Hey mgb1978 your right it was really hard to punch the scuttle without damage it i had to prop under the panel with some metal just so i didnt damage it in any way when i hit it worked like a treat. I punched it into the inner sill to so hopefully this will keep nct crowd happy.
