Spare parts Cork
- Whats your location?: Carrigaline, cork, Ireland
Re: Spare parts Cork
What parts are you looking for exactly?
I am looking for a few items;
Clutch slave cylinder
Flexi pipe from master cylinder to slave cylinder
Oil dip stick
Driver side door lock mechanism
All for a 99 cooper.
If I can get these in cork it would be great if not I will order on line.
Oil dip stick
Ian, Miniquip on here, would have most if not all of those in stock and delivers to Southern Ireland for a few quid.
If you are looking for some of the items second hand, Mustard is breaking his Mini at the mo and Paul Kelly (Jocelyn) always has a good supply of bits. There are probably a few more guys on here with some of the parts you need.
I'l probably get the parts for the clutch new and use miniquip for that but the other parts I could use second hand alrite, do you have contact numbers for those guys? Are they based in cork ?
Thanks again for your help
They are Meath and Dublin, but getting parts down to Cork mightn't be too big a deal, there should be a few SR members at the Portlaios run this weekend.
- Whats your location?: midleton, county cork.
- What Minis have you?: 1985 MINI
1991 MINI
1975 MINI CLUBMAN ESTATE - Contact:
Hi I have alot of parts.
I am in midleton so im close enough to u. i have a door in the back of my garage should have the lock mechanism on it
Sam,
I'm working in Knockgriffin. Whereabouts are you?
Hi
I managed to pick the door lock today, but still looking for the other parts and it would be great to get them local if you had them?
Users browsing this forum: No registered users and 36 guests
