Blocking up vents?
daveq
Blocking up vents?
Post by daveq »
What's the general consensus on blocking up the vents?
I found a large area of rust around one of mine and wondering whether to repair it or just block it up?
Re: Blocking up vents?
you are going to have to weld metal in there anyway, i'd repair it then rust-proof like a mad thing!
I blocked mine up years ago . I used alloy plate .
You can get an inner flitch repair panel which you can cut and repair the rust.This is a common rust problem on Minis with fresh air vents and personally speaking I would not block them up as they are very useful on a warm day and as near to A/C as you will get on most Minis.The panel is not expensive as well.
http://www.somerfordmini.co.uk/eshop/in ... cts_id=119
A block,em up and roll the window down :lol:
des
Post by des »
My 73 has the vent holes, but blocked by a round factory fitted panel, held with about 6 small screws. So blocking it should not be a problem.
