wireing up a radio
- Whats your location?: celbridge co kildare
- What Minis have you?: 92 city and 83 leyland 1000
- Modifications: zeemax kit 1330 engine
wireing up a radio
i have no radio in my 83 leyland and im fitting a new one i had lying arround i need a live, and a switch live and an earth .the earth is handy but where do i take the lives from
Re: wireing up a radio
take the permeant feed from the brown wire on the ignition and the switch is the green with white strip
is that on the wires going into the ignition barrel
That's it but make sure to put an in-line fuse on the 2 live's going to the radio.
- Whats your location?: Seaforde, Ballynahinch, Co. Down
- What Minis have you?: 1961 Austin 7, 1988 Mayfair, 1964 Van, 1981 van, 1976 Pick-up, 1980 Pick-up, 1968 Wolseley Hornet, 1978 1275GT, 1986 Rally special
I always pull the live and switched feeds from the standard fuse box, simples......
Ian
MINI QUIP
http://www.mini-quip.co.uk
MINI QUIP
second that: theres a couple of spare terminals there usually and its a lot easier to reach than the ignition. IIRC the "switched" is colour white.Miniquip wrote:I always pull the live and switched feeds from the standard fuse box, simples......
