Woundering can anyone help me with advise on what to do with or where to get ...
oxygen/emmision sensor that broke off my exhaust, the needle broke just at the tipp of the bolt shown
another sensor that broke off the bottom of the carb when i was taking it off, the other end bolts into the carb, cant be fixed so if anyone knows where to get a new 1??
this one is out of the air intake, its cut and the wires are not connected.. could patch up this one but if anyone has an idea of da best ting to do that would be great.
thanks in advance.
sensors problem
- Whats your location?: strokestown road
co. longford - Region: Western
- What Minis have you?: 1995 jap-imported spi cooper
1974 Australian clubman panel van - still in oz - Modifications: Adjustable gaz shocks and adjusta ride height, 6x12 deepdish minilights ultimate engine steady, grp 2 arches, maniflow exhaust.
Re: sensors problem
Id Imagine the First one is your lambda sensor and the last is a air temp sensor if its in the intake of the TB.
Id guess the lambda is a Narrowband sensor, I think these are a standard thread and fit, They are around e30 on ebay.
Air temp sensor Id, just solder the wires together, although it could be a pain as its so close to the plug. The sensors are about e15.
I have no Idea what the middle one is for. Do you have a haynes manual? maybe a manifold heater?
Re: sensors problem
That Lamda sensor is totally different to the UK Mini one which is located on the manifold.
- What Minis have you?: '94 BRG Rover Cooper
Re: sensors problem
The last sensor is located after the cat. It measures the exhaust gas temperature and determines whether the cat is working properly. It is only fitted on jap spec minis and all it does is turn on a warning light on the dash as far as I know. Its here on somerford mini site no. 62. http://www.somerfordmini.co.uk/eshop/in ... page&id=76
Re: sensors problem
DustyM wrote:The last sensor is located after the cat. It measures the exhaust gas temperature and determines whether the cat is working properly. It is only fitted on jap spec minis and all it does is turn on a warning light on the dash as far as I know. Its here on somerford mini site no. 62. http://www.somerfordmini.co.uk/eshop/in ... page&id=76
Thanks dustyM.. it wont be re connected soon so seen as im taking out the cat. will get 1 when im getting a few bits,
thanks for that, tho
