Rocky Drive!
Posted: Wed Apr 06, 2011 9:50 am
by loxley
Hi all,
I am wondering about the bearings in my diff, there seems to be alot of play...ie. i can rock the drive shaft coupler about a bit..... I persume this is bad news!, any ideas, thoughts, info on changing would be greatly appreciated, can i take the diff off with the motor in situ?....
in a very much related issue would a box from a mpi swap straight onto the spi??
Thanks in advance...
Re: Rocky Drive!
Posted: Wed Apr 06, 2011 11:34 am
When you say you can rock the coupler about a bit, how exactly do you mean , in out, forward back, up down ?
Do they move independently or together ?
Are the drive shafts in or out ?
Any work on the diff itself will be an engine out job.
Re: Rocky Drive!
Posted: Wed Apr 06, 2011 11:50 am
by loxley
The drives are still connected, when i grab the coupler coming from the diff I can get up/down movement, which to me feels like the bearings are really worn... will the mpi box fit directly onto the spi engine?
Re: Rocky Drive!
Posted: Wed Apr 06, 2011 12:01 pm
by BERT
Gearboxs are the same except for a different crown wheel and pinion ratio
Re: Rocky Drive!
Posted: Wed Apr 06, 2011 7:42 pm
by GTM Coupe
If you had that much play the output shaft seal would be knackered and you would have lots of oil draining out of the box, I would say probably a worn inner CV joint
