Gearbox Question
- EAMOSPUD
- Whats your location?: The Rebel County ...
- What Minis have you?: 1972 mini 850
- Modifications: None ( Well nearly none... ) twin 1"1/4 su carbs , KN filters, cooper freeflow manifold, RC40 single box side exit.
Gearbox Question
I have a 72 mini 850 with a original type gearbox , Magic wand type, (not remote or rod change)
Car has no reversing light as standard and just wondering has gearbox a hole to take early reversing light switch.
I see there is a switch available for early type cars.
Is it possible to fit same to my current model.
Has anyone done this.
Eamonn
Eamonn
Re: Gearbox Question
Should have a bolt in place of the switch as you look into the engine bay its just right of the oil filter if memory serves me right
- EAMOSPUD
Good Man, spotted that nut today , have not removed it yet do.
Will keep ya posted
Thanks for help.
Will keep ya posted
Thanks for help.
Its a long time since I did this but I think when you remove the bolt there is a spring and you havee to fit a rod down the center of the spring that will operate the switch. You need a calipers to work out the lenght of rod needed.
- EAMOSPUD
Took a quick look tonight
Yes spring inside and as you said a plunger needed to operate switch
Need to source suitable piece and play around with length
Job for next few weeks
Other jobs to finish first before Sunday run
You were allowed look at your mini on Valintines night! Must be love
- EAMOSPUD
Let's just say, Filling the bucket of coal from the shed took a bit longer than normal........!!!!!!!
Calling the missus a shed is worse......
- EAMOSPUD
Just wondering But has this gone of topic a bit
It would take you to get the wrong end of stick..................
Thanks for that.............
