electrical problems
- Whats your location?: celbridge co kildare
- What Minis have you?: 92 city and 83 leyland 1000
- Modifications: zeemax kit 1330 engine
electrical problems
had a good and bad day with the mini changed the clutch slave cylinder and hose and got the car back driving again left to bring the mini home and found a load of electrics not working 1 no indicators 2no hazzards 3 no sidelights but had dip beam and head lights 4 no rear lights 5 no break ligfhts 6 no wipers any ideas i know when i brought the car out last time i had rear lights and wipers cause i changed the motor any ideas all fuses seem fine but noticed second fuse from bottom was warm i hate mini electrics
- pick up man
Re: electrical problems
I'm no expert on electrics but for all those to be gone at the one time and all fuses ok, it would lead me to look at the earthing point.
If you have headlights but no side or rear lights it most likely No. 4 fuse. Check the brown wire connection at solinoid.
Thanks for the replys connection on the solenoid could be a runner yesterday i changed clutch slave cylinder and flexi hose so will definetly check that tomoro night
