hi lads.
just wondering what the symptoms of a stepper motor giving problems are???? i have a 95 sprite spi and notice that it takes ages to settle down to a nice idle after driving.....if i put my foot under the acc pedal and pull it up it seems to idle slower..and when driving, changing gear it stays at the higher revs. any ideas?
thanks
stepper motor
- Merlin
Re: stepper motor
I could well be a stepper motor Tony they give a lot of problems on SPI's it could also be a faulty Throttle position sensor, or it could be as simple as a failing return spring !
If you want to take a spin up to My garrage I could run a Diagnostic check for you and reset the Idel steper motor,
Where open untill 7:30PM monday to Friday
Best Regards,
Paul
HRE
(086) 816 0774
Best Regards,
Paul
HRE
(086) 816 0774
Re: stepper motor
Paul would you consider putting a link to a google map for your garage?
Re: stepper motor
thanks paul, will be in touch to arrange a time,, need to put her through the nct first,,,
thanks again
tony
thanks again
tony
