spray painting tips/help??
Posted: Fri Jul 16, 2010 7:11 pm
by benfox1515
over the last two weeks I have been working out the rust spots on the mini, treated them and filled them in. The easy part!! I am now starting to spray it, using aerasol spray paint made up by vinny byrnes. I have done a few coats of primer and a few coats of the colour, but its not blending in well with the orginal paint as it is not very shiney! When I got the paint I asked them did I need lacquer and they said there was no need as the paint is a high gloss. Is it just a thing that I have not done enough top coats?? I think I did about three?
Re: spray painting tips/help??
Posted: Fri Jul 16, 2010 7:20 pm
by daniel garry
u could flat the paint with 2000 grit wet and then use rubbing compound
Posted: Fri Jul 16, 2010 7:45 pm
by steeo
Are you spraying inside or outside ???
Cold weather or cold panels can affect the finish on paint.
As for blending in with the original colour that will be nearly impossible as the original paint would have faded over the years.
Posted: Fri Jul 16, 2010 8:26 pm
by D.M.G.T
Its near impossible to match paint with aerasol paint to get a shine..
youll have to spray to the seems on the body or the hole panels that your working on.this will not make the areas you did stand out to much..
Posted: Fri Jul 16, 2010 9:06 pm
by benfox1515
The new paint is nearly a match for it. I didn't have the code as it's not the original colour so vinny Byrnes matched it for me. It's when I have it on the new paint is very matted not shiney at all
Posted: Fri Jul 16, 2010 9:54 pm
by steeo
[quote="steeo"]Are you spraying inside or outside ???
Cold weather or cold panels can affect the finish on paint.[/quote]
Posted: Fri Jul 16, 2010 11:06 pm
by benfox1515
Spraying outside, unfortunately. But weather had not been too cold.
Posted: Sat Jul 17, 2010 1:09 am
by daniel garry
Posted: Sat Jul 17, 2010 1:58 am
by armo
the type of paint you got is 2k mixed in a can its not the best and wont cure enuf .... it will not blend unless you use fade in tinners this will blend it and allow you to polish then it should be perfect thats if it cures enuf if it doesnt then youl have to start agen ..what Colour is your car?
Posted: Sat Jul 17, 2010 11:19 am
by benfox1515
It is a dark blue. How would you apply the thinner!? Would it be in an aerosol!?
Posted: Sat Jul 17, 2010 1:00 pm
by armo
is it metallic ??? yes you can buy it in a can and give the area a coat
Posted: Wed Jul 21, 2010 7:51 am
by Gav88
I'm emigrating and have a new HVLP sealy pro spray and a tidy air compressor going really cheap if your looking for something a bit higher quality then a spray can ?
