1990 998,clock conversion
Posted: Thu Jun 24, 2010 2:15 am
hello,im nearing finishing my mini project which i will post up asap, but im having a bit of bother converting from the 2 clock set up to 3 clock,the clocks work perfect but how is the 3 clock assembly actually mounted?i take it you use the same mounting brackets but how exactly does it work? any help appreciated
