Any wiring gods??
stevie g
Whats your location?: Saggart co Dub
What Minis have you?: 1977 998 & 1980 998
Modifications: So low I'm scratchin the road!!
Any wiring gods??
Post by stevie g »
My indicators just stopped working,I just replaced the flasher but to be sure I got a new one,no joy
my hazards work so I'm thinkin it may be the stalk? Any ideas?
yellowminiman
Re: Any wiring gods??
Post by yellowminiman »
did you check the two inline fuses under the scuttle panel behind carb
92Coop
Post by 92Coop »
also stevie, if that doesnt work, unscrew all indicator surrounds and check for water ingress.
i had terrible trouble with indicators on my old cooper, and it was all down to corroded contacts
within the light itself. backs of the bulbs were covered in rusty gunk. a quick sandpaper job and
i was right as rain.
stevie g
Post by stevie g »
yellowminiman wrote:did you check the two inline fuses under the scuttle panel behind carb
I can only find one fuse there???
miniireland
Post by miniireland »
did you re connect the 2 wires that you snapped off the spade for the flasher unit ,give the plugs under the steering column a wiggle they are notorious for loose connections....
clubmankev
Post by clubmankev »
The hazard switch is a possible culprit.
MINI
...where size doesn't matter!
stevie g
Post by stevie g »
miniireland wrote:did you re connect the 2 wires that you snapped off the spade for the flasher unit ,give the plugs under the steering column a wiggle they are notorious for loose connections....
yea I sorted that,had it working and all
stevie g
Post by stevie g »
clubmankev wrote:The hazard switch is a possible culprit.
sound,I'll look at that in the morn
miniireland
did you get the correct flasher unit ,the hazard problem only happens on cars that dont have functioning hazard lights, i.e if you leave the hazard light switch in the on position it overides the indicators at the stalk, but this particular car has functioning hazard lights, try putting the old unit back in, also the plugs under the steering column open and clean the contacts aswell
stevie g
Post by stevie g »
I got the multimeter on it today,I think it might be the stalk
There are two seperate flasher units for hazard and indicator. What year car is this?
