Page 1 of 2
honda b16a clubby estate
Posted: Tue May 11, 2010 12:13 am
by minivinnie
first time poster here but long time mini man
its been on the long finger for quiet a long while but its being resurected again,ill stick up some pics tomorrow...of how it used to be and how it looks now.after collecting loads of parts,engine,box and minitec subframe,shafts etc etc i think is time to get craking at this machine!! stay tuned!!
Re: honda b16a clubby estate
Posted: Tue May 11, 2010 12:23 am
by joeyfinneran
Welcome to the forum and hope it helps you out with your vtec mini
I just love vtec minis
Posted: Tue May 11, 2010 12:26 am
by minivinnie
joeyfinneran wrote:Welcome to the forum and hope it helps you out with your vtec mini
cheers !its been way to long in a shead and im getting the urge again to get back into it!
Posted: Tue May 11, 2010 12:29 am
by joeyfinneran
B16a that's the 1.6 isn't ? If u put in a 1.8 there too much metal to cut away or put on the extended nose and they just rune it (in my opion)
Posted: Tue May 11, 2010 12:33 am
by StevenR
Good man Vinnie. I remember this car from shows a few years ago good to see your starting work on it again.
Posted: Tue May 11, 2010 6:33 pm
by minivinnie
joeyfinneran wrote:B16a that's the 1.6 isn't ? If u put in a 1.8 there too much metal to cut away or put on the extended nose and they just rune it (in my opion)
theres no need to lengthen the front with this kit.
Posted: Tue May 11, 2010 7:14 pm
by miniireland
minivinnie wrote:joeyfinneran wrote:B16a that's the 1.6 isn't ? If u put in a 1.8 there too much metal to cut away or put on the extended nose and they just rune it (in my opion)
theres no need to lengthen the clubman for either engine
Posted: Tue May 11, 2010 7:49 pm
by minivinnie
miniireland wrote:minivinnie wrote:joeyfinneran wrote:B16a that's the 1.6 isn't ? If u put in a 1.8 there too much metal to cut away or put on the extended nose and they just rune it (in my opion)
true,no need to lengthen the bull nose either with the kit i have.
Posted: Thu May 13, 2010 11:14 pm
by minivinnie
Posted: Thu May 13, 2010 11:20 pm
by minivinnie
and some of the new bits and pieces to be fitted in the oncomming weeks
coustom made alloy red and slim line electric fan
minitec subframe
rebuile kit for the rear disks,the first ones had problems with the seals
new fanbelt tensioner,and front shouh mounts
equal lenght drive shafts..
and the new enging and 5 speed box
Posted: Thu May 13, 2010 11:49 pm
by StanO'Toole
Mmmmmm............................. I think I just wet myself! That Clubby is slammed, wouldn't be getting over many ramps will you?
Posted: Thu May 13, 2010 11:53 pm
by minivinnie
StanO'Toole wrote:Mmmmmm............................. I think I just wet myself! That Clubby is slammed, wouldn't be getting over many ramps will you?
is on adjustable hi-lo and gaz shocks and never had any problems to be honest,the arches are quiet flexible to which always helps!
Posted: Fri May 14, 2010 12:02 am
by StanO'Toole
They must be adjusted to the last! Looks sweet, and will go sweet once you throw in the jap scrap. People won't know what hit them when they hear something hitting V-tec and seeing a Clubby estate coming for them flat out!
Posted: Fri May 14, 2010 1:47 am
by mustard
love the clubby, looks sweet... the rear lights look cool
Posted: Fri May 14, 2010 7:35 am
by CLUBMANGT
OOOOOOOOH!!!! YES SWEET
nice one ,sorry but must know we all want one !
Posted: Fri Aug 13, 2010 10:57 am
by just_st3v3n
hows this coming along? any more pics?
Posted: Wed Aug 18, 2010 10:23 pm
by keith
really interesting... !!! the subframe & engine kit look really sweet. cant wait to see that in the metal!
also very curious about the front mounted rad you had for the metro engine set-up.. . . what car was it from? did you have any problems with it? here is my front rad set-up:
Posted: Thu Aug 19, 2010 7:25 am
by mustard
keith wrote:really interesting... !!! the subframe & engine kit look really sweet. cant wait to see that in the metal!
looks like an alloy rad for a honda civic
Posted: Thu Aug 19, 2010 11:51 am
by keith
just making it clear:
Posted: Thu Aug 19, 2010 7:00 pm
by mustard
keith wrote:just making it clear:
woops my bad
Posted: Tue Mar 22, 2011 10:27 pm
by minivinnie
its been a while since ive been on here,its still on a bit of a go slow at the min,im in the process of finishing off one of my other projects
but the mini hasnt been forgotten about!
Posted: Thu Mar 24, 2011 8:51 pm
by aidstap
a word of advice before you fit the frame for the last time change the bolts to the suspension arms to the other way around or if you ever have to take the arms off you will have to remove the frame, also what are your plans for the steering rack? seen as the frame is designed for lhd?
Posted: Sat Apr 02, 2011 10:55 pm
by craig_farrell
always dreamed about a vtec mini
looks like a nice project.
Posted: Sun Jul 31, 2011 5:50 pm
by minivinnie
looking for 2 front complete doors for this at the moment,any knocking around?
Posted: Sun Jul 31, 2011 5:55 pm
by keith
pm sent....
