Indicators not working
Posted: Sun Apr 04, 2010 5:48 pm
by sconson
Hi lads,
indicators don't seem to be working altho the hazzards work fine, any suggestions as I can't really drive it without indicators!!
Cheers
Posted: Mon Apr 05, 2010 8:20 pm
by MiniMe
Could be a fuse; hazards run on a different circuit
Posted with
TouchBB on my iPhone
Re: Indicators not working
Posted: Mon Apr 05, 2010 8:25 pm
by antodeco
I have the exact same issue. Hazards work fine, but not the indicators. Brake lights are also gone. I was thinking that the indicator stalk might be dodgy, but the horn works on it.
Posted: Mon Apr 05, 2010 8:39 pm
by sconson
Replacing the fuses tomorrow so fingers crossed!
Posted: Mon Apr 05, 2010 9:04 pm
by antodeco
Which set of fuses are the indicators?
Posted: Mon Apr 05, 2010 9:09 pm
by just_st3v3n
antodeco wrote:I have the exact same issue. Hazards work fine, but not the indicators. Brake lights are also gone. I was thinking that the indicator stalk might be dodgy, but the horn works on it.
thats your fuse, the two of them are on the same fuse circuit.. check to see if its gone or could be the connections.
sconson wrote:Hi lads,
Cheers
as above you'll know if its a fuse if your brake lights dont work as they are on the same circuit.
if the fuse isnt gone check the connections on the fuse box. if everything seems fine there get back in the car..
stick your head under the right side of the steering wheel and there should be a little box (indicator flasher unit) that would be your culprit.. ya can get them in most motor factors for a few quid...
steven
edit
antodeco wrote:Which set of fuses are the indicators?
think its the second one from the top
Posted: Mon Apr 05, 2010 9:18 pm
by Gav88
aAll of the above work and decide not to work in mine when they feel like it, tore out the dash to find some wires getting hot, think its a grounding issue, I'm sick of toying with a multi meter upside down, backwards and inside out
. Anyone got a number for a good auto electrician in munster ?
Posted: Mon Apr 05, 2010 10:37 pm
by just_st3v3n
Gav88 wrote:aAll of the above work and decide not to work in mine when they feel like it, tore out the dash to find some wires getting hot, think its a grounding issue, I'm sick of toying with a multi meter upside down, backwards and inside out
faulty connections at the fusebox??
i ditched the original fusebox and got a 6 fuse one that uses the more modern spade fuses, problems solved
Posted: Tue Apr 06, 2010 12:13 pm
by daniel garry
is u'r car an spi?? its fuse 10 in the fuse box but is u'r radio working?? they're on the same fuse
Posted: Tue Apr 06, 2010 1:02 pm
by sconson
steven
Replaced the Flasher unit and still no joy
daniel garry wrote:is u'r car an spi?? its fuse 10 in the fuse box but is u'r radio working?? they're on the same fuse
Not sure what spi stands for
Its a 1992 Mini Cooper if that helps??
Radio works fine, what fuses do I replace and where can I find them?
Posted: Tue Apr 06, 2010 1:20 pm
by daniel garry
single point injection, is ur car injected or has it got a carb??
Posted: Tue Apr 06, 2010 1:32 pm
by sconson
Injection as far as I know.
