Indicators not working
- What Minis have you?: 1992 Mini Cooper
- Modifications: Below were on the car when I bought it.
• Clarion sound system with speakers built into back shelve
• K&N air filter
• Roll cage - Location: Dublin
Hi lads,
indicators don't seem to be working altho the hazzards work fine, any suggestions as I can't really drive it without indicators!!
Cheers
Cheers
- antodeco
Re: Indicators not working
I have the exact same issue. Hazards work fine, but not the indicators. Brake lights are also gone. I was thinking that the indicator stalk might be dodgy, but the horn works on it.
• K&N air filter
Replacing the fuses tomorrow so fingers crossed!
- just_st3v3n
thats your fuse, the two of them are on the same fuse circuit.. check to see if its gone or could be the connections.antodeco wrote:I have the exact same issue. Hazards work fine, but not the indicators. Brake lights are also gone. I was thinking that the indicator stalk might be dodgy, but the horn works on it.
as above you'll know if its a fuse if your brake lights dont work as they are on the same circuit.sconson wrote:Hi lads,
Cheers
if the fuse isnt gone check the connections on the fuse box. if everything seems fine there get back in the car..
stick your head under the right side of the steering wheel and there should be a little box (indicator flasher unit) that would be your culprit.. ya can get them in most motor factors for a few quid...
edit
think its the second one from the topantodeco wrote:Which set of fuses are the indicators?
some day....
- What Minis have you?: 89 mayfair,
91 city project! - Modifications: Stage 1kit, custom interior, bits and pieces, have a look
aAll of the above work and decide not to work in mine when they feel like it, tore out the dash to find some wires getting hot, think its a grounding issue, I'm sick of toying with a multi meter upside down, backwards and inside out
. Anyone got a number for a good auto electrician in munster ?
- just_st3v3n
faulty connections at the fusebox??Gav88 wrote:aAll of the above work and decide not to work in mine when they feel like it, tore out the dash to find some wires getting hot, think its a grounding issue, I'm sick of toying with a multi meter upside down, backwards and inside out. Anyone got a number for a good auto electrician in munster ?
i ditched the original fusebox and got a 6 fuse one that uses the more modern spade fuses, problems solved
some day....
- daniel garry
is u'r car an spi?? its fuse 10 in the fuse box but is u'r radio working?? they're on the same fuse
• K&N air filter
Replaced the Flasher unit and still no joyas above you'll know if its a fuse if your brake lights dont work as they are on the same circuit.
Not sure what spi stands fordaniel garry wrote:is u'r car an spi?? its fuse 10 in the fuse box but is u'r radio working?? they're on the same fuse
Radio works fine, what fuses do I replace and where can I find them?
- daniel garry
• K&N air filter
Injection as far as I know.
