Halford 20 W 50 oil
Posted: Sat Apr 03, 2010 11:03 pm
by DaveC
Has anyone tried the halford's own brand 20 W 50 engine oil?
Re: Halford 20 W 50 oil
Posted: Sat Apr 03, 2010 11:55 pm
by keith
dave, yes i have it in the SPi at the moment... about 2000 miles so far, inc a rather quick trip to cork & back.
found it to be a little "thin", and not sure how well it likes constant high speed (4000rpm for 2 hours); after coming off the m/way i noticed the pressure had dropped to below 50 psi at idle..
what had you been using?
*edit* i note that Ashgrove Interparts had COMMA 20w50 available 2 weeks ago when i was in. priced similar to Halfords.
Posted: Sun Apr 04, 2010 12:03 am
by DaveC
Keith, not sure what is in it at the moment, but might pop in to Ashgrove for a look
Posted: Sun Apr 04, 2010 11:37 am
by Deadly Dave
Ashgrove buy oil in by the pallet. If there was enough interest they would probably buy in a pallet of a good brand 20w 50 for us.
Posted: Sun Apr 04, 2010 10:11 pm
by Jobber85
Is halfords own brand antifreeze coolant ok? It complies with BS6580 standards so i assume so?
Posted: Sun Apr 04, 2010 11:50 pm
by keith
antifreeze is a whole different matter... . pretty much anything with a bit of anti-corrosive and anti-freezing properties should do. unless you are running and alloy head.... . . anyone? paul???
Posted: Sat Apr 10, 2010 2:32 pm
by marcexec
Jobber85 wrote:Is halfords own brand antifreeze coolant ok? It complies with BS6580 standards so i assume so?
We had to replace the whole coolant (was only rusty water!) and that Halfords stuff (ready mixed, 5ltr) is OK, I did some research beforehand.
Never had any problems, but we only have been doing short trips only: <30km.
Posted: Sat Apr 10, 2010 6:36 pm
by keith
ashgrove interparts have two 20w50 oils.... both by COMMA, one 4.5lt @ 18.50 euro in a plastic bottle, another 5lt @ 30.00 euro in a tin, marked "classic".
i'd want to know whats in the tin to be 50% more expensive than the other...
on the other hand, i did find a new 5lt of duckhams under some stuff in my shed...
Posted: Sat Apr 10, 2010 7:04 pm
by kona
I use halfords 20w50, Never used anything else, car is fine, no rattles bangs or issues. Its e19.99 for 5lt and you get 15% off witha axa insurance policy.
I have a Trade Card and I got Bosch HT Leads and Ngk Bcpr7es plugs, 20w50 oil all for under €35. Cheap Service, I usually order Unipart fiters from minispares when im getting stuff from them as I dont really trust any other Brands.
Posted: Sat Apr 10, 2010 10:47 pm
by tony
hi all,
duckhams do a 20w50 engine oil, its known as duckhams Q 20/50,,, duckhams is now distributed by castrol so any motor factor should have a few tins in stock,, not used it myself as i have been using 10/40 in my spi since 2000,,,the only problem i have is gear rod seals about once a year,, maybe a thicker oil wouldnt leak or maybe that seal is just one of those lovely mini quirks that we come to take for granted?
Posted: Sat Apr 10, 2010 11:06 pm
by gareth
No matter what year mini your best stick with the 20/50. The gearbox needs the thicker oil and the mpi boxes are soft enough as it is so need all the help they can.
Posted: Sun Apr 11, 2010 1:39 am
by marcexec
yeah, followed the whole discussion in the German forum:
Irish weather: 20W50, you can do 15W40 over Germany's winter - like -10°C to max 5°C
So would have been nice in the last winter here as well.
Personally I am using Millers Mini Oil (Miniquip sells it), and I believe that extra 5€ are not too much.
Some guys go with Motorcycle Oil, especially if the engines are tuned. Not a bad call either since there are a lot of similarities.
Posted: Sun Apr 11, 2010 10:13 pm
by mark halford
comma oil meant to be good and not to bad of a price can get it for €14.50 for 5ltr localy in motor factors in arklow town
