My first mini,smokey.
martind81
Post by martind81 »
Right i finally bought a mini and have now proceeded to gut it!!!!
started a blog detailing what ive done and am going to do.
The blog is located here: http://shesamini.blogspot.com/
ill transfer everything over to here eventually but for the time being it'll have to stay as a blog!!
I do all my own stunts.
http://www.explosivedjmusic.ie for all your entertainment needs!
Re: My first mini,smokey.
Nice read.
Why are you changing the gearbox, just change the CV's.
martind81
Post by martind81 »
Got new drives with the car and apparently (according to that peter chap) it'll be a tight squeeze to fit that gearbox in, i might even have to do some chopping!
i'm open to correction on this.
Plan on doing all the body work and interior first and then tackle the engine side of things so ive plenty of time to suss out whats the best options.ill be rebuilding the engine so to change the gearbox, if i have too, won't be a massive amount of work.
would i be right in assuming that the drives on the gearbox i have woudn't be on the newer gearboxes?
just_st3v3n
Post by just_st3v3n »
nice little blog...
if ya ask me that looks like a normal mini gearbox :roll:
some day....
martind81
Post by martind81 »
thanks.
yeah as far as i can make out its the same (size anyway) but the outputs are diffeerent. Pre 1974 so ive been told.
ill take it apart in a few weeks and we'll all see then.
Have you a photo of the back of the gearbox and the drives ?
The 1300GT engine is the same as a Mini 1275 engine, they share a common gearbox too, the only thing that might be slightly different may be the gear ratio or the final drive .
Took out the windscreen - 10 second job and no i did't use a hammer!
:lol: Bril :lol: Cool blog, a very good way to keep a record of everything. Keep it up :mrgreen:
martind81
Post by martind81 »
The Marcos Graveyard wrote:Have you a photo of the back of the gearbox and the drives ?
http://picasaweb.google.com/lh/photo/8Z ... directlink
ahhhhh photos!!!!!!!
i got the idea from a friend whose restoring an MGB GT and keeps a similar blog. Just nice to have it all in the one place and when its finished you can export/save it or copy it to another blog host site! Was never really into blogs/facebook/twitter etc. but now that i actually have a use for a blog i can kind of see the point.
Thats a remote gear change, you need the older style linkage, but it will fit without any body mods.
martind81
Post by martind81 »
[quote="The Marcos Graveyard"]Thats a remote gear change, you need the older style linkage, but it will fit without any body mods.[/quote]
Thats good news! Looks like the gearbox is staying! I think i may have the gear linkage for it, long alu casting that bolt to the tunnel under the hole for the gear stick.
That's the boyo :D
martind81
Post by martind81 »
Sick as a dog! But im going to get that flip front on today!
martind81
Post by martind81 »
11 cups of tea, 4 bottles of water and 4 panadol later....the flip front is on!! will get some photos up later.
Id like to recommend NOT trying to do this hungover!
martind81
Post by martind81 »
Have been flat out in work and karting most weekends for the past few weeks but i got a bit done over the weekend (well an hour Sunday night!) took out the rear sub frame and started stripping it. was planning on giving it a good clean and a few coats of hammerite, was wondering is there anything i should be doing now that is out and on the ground? Ive a set of hi los and a poly bush set to go into it which i plan on doing and i might strip the hubs and see what nice surprises are in there!
Users browsing this forum: No registered users and 35 guests
